跳转到主内容
Toshiba Satellite C55-C5268 Disk Drive Replacement
你所需要的
  1. Toshiba Satellite C55-C5268 Disk Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Disk Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C55-C5268 Disk Drive Replacement: 步骤 2 中的图像 2,2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Disk Drive Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Disk Drive Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C55-C5268 Disk Drive Replacement: 步骤 4 中的图像 2,2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Disk Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C55-C5268 Disk Drive Replacement: 步骤 5 中的图像 2,2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 Disk Drive Replacement, Disk Drive: 步骤 6 中的图像 1,1
    • Unscrew one 3.0 mm screw from the disk drive using a #1 Phillips screwdriver.
  7. Toshiba Satellite C55-C5268 Disk Drive Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite C55-C5268 Disk Drive Replacement: 步骤 7 中的图像 2,2
    • Grab the disk drive with one hand and the laptop with another, then gently pull the disk drive straight toward yourself.
    • Pull it in a straight line horizontally until it is completely removed.
    • This does not require much force, so be gentle.
结论
Ben Rounseville
于10/21/16注册
471 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G1
2 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 394
