跳转到主内容
Toshiba Satellite C55-C5268 Battery Replacement
你所需要的
  1. Toshiba Satellite C55-C5268 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Battery Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C55-C5268 Battery Replacement: 步骤 2 中的图像 2,2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
结论
另外一个人完成了本指南。
Greg Smith
于10/24/16注册
347 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G1
2 名成员
创作了12篇指南
2条评论
Thanks, l think my battery is dead, charged it for 12 hours and base never got hot, not charging, right? Computer does not come on at all.
bribocall - 回复
Hello! i have TOSHIBA SATELLITE C55-B1065 Laptop and i’m wondering what is the good battery i should buy ?
sana aissaoui - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 111
总计 16,865
