当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Unplug and power off the laptop.
Unscrew the two 9 mm Phillips #1screws holding the battery in place.
Grab the battery and pull it away from the laptop to remove it.
This doesn't require a lot of effort, so you don't have to pull too hard.
Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
Using a metal spudger can damage sensitive components.
Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
Pry up the back panel from the rest of the laptop using a spudger.
It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于10/21/16注册
471 声望
创作了4篇指南
徽章: 12
+ 9更多徽章
UMASSD-CATANIA-F16S4G1
2 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 26
总计 1,822
