跳转到主内容
Toshiba Satellite C55-C5240 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Hard Drive Replacement, Back cover: 步骤 3 中的图像 1,2 Toshiba Satellite C55-C5240 Hard Drive Replacement, Back cover: 步骤 3 中的图像 2,2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 3,3
    • The hard drive is on the bottom left side.
    • Remove both releases from the rubber hard drive mount.
  6. Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 6 中的图像 1,3 Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 6 中的图像 2,3 Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Lift the hard drive from underneath on the right side.
    • While holding it up, pull it away from its connector so that it disconnects.
  7. Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite C55-C5240 Hard Drive Replacement: 步骤 7 中的图像 3,3
    • Peel off the rubber hard drive mount.
结论
5等其他人完成本指南。
团队
USF Tampa, Team S1-G5, Nance Spring 2017 USF Tampa, Team S1-G5, Nance Spring 2017 的会员
USFT-NANCE-S17S1G5
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 11
总计 1,658
