跳转到主内容
Toshiba Satellite C55-C5240 RAM Replacement
你所需要的
  1. Toshiba Satellite C55-C5240  RAM Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite C55-C5240  RAM Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite C55-C5240  RAM Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240  RAM Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite C55-C5240  RAM Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite C55-C5240  RAM Replacement: 步骤 2 中的图像 3,3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240  RAM Replacement, Back cover: 步骤 3 中的图像 1,2 Toshiba Satellite C55-C5240  RAM Replacement, Back cover: 步骤 3 中的图像 2,2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240  RAM Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite C55-C5240  RAM Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite C55-C5240  RAM Replacement: 步骤 4 中的图像 3,3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240  RAM Replacement, RAM: 步骤 5 中的图像 1,3 Toshiba Satellite C55-C5240  RAM Replacement, RAM: 步骤 5 中的图像 2,3 Toshiba Satellite C55-C5240  RAM Replacement, RAM: 步骤 5 中的图像 3,3
    • The RAM is at the upper middle area of the motherboard.
    • Push down on the clips on either side of the RAM stick evenly.
    • It will come loose in an angle once the clips are released.
  6. Toshiba Satellite C55-C5240  RAM Replacement: 步骤 6 中的图像 1,1
    • Simply pull out the RAM stick.
    • These steps work for both sticks of RAM.
结论
Angela Rodriguez
于02/28/17注册
261 声望
创作了2篇指南
团队
USF Tampa, Team S1-G5, Nance Spring 2017 USF Tampa, Team S1-G5, Nance Spring 2017 的会员
USFT-NANCE-S17S1G5
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 18
总计 1,463
