跳转到主内容
Toshiba Satellite C55-B5302 laptop Memory chip (RAM) Replacement
你所需要的
  1. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 步骤 3 中的图像 1,1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): 步骤 4 中的图像 1,3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): 步骤 4 中的图像 2,3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): 步骤 4 中的图像 3,3
    • Remove the remaining thirteen 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 步骤 5 中的图像 3,3
    • Push down on the two clips holding the RAM chip in place.
    • Pull the RAM chip up slightly and out away from the connection to remove.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 1,138
