跳转到主内容
Toshiba Satellite C55-B5302 Webcam Replacement
你所需要的
  1. Toshiba Satellite C55-B5302 Webcam Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite C55-B5302 Webcam Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 3 中的图像 1,1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Webcam Replacement, Fan: 步骤 4 中的图像 1,3 Toshiba Satellite C55-B5302 Webcam Replacement, Fan: 步骤 4 中的图像 2,3 Toshiba Satellite C55-B5302 Webcam Replacement, Fan: 步骤 4 中的图像 3,3
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 5 中的图像 1,1
    • Disconnect the fan wire from the motherboard.
  6. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 6 中的图像 1,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 6 中的图像 2,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 6 中的图像 3,3
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  7. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 7 中的图像 1,1
    • You can now lift the fan out of the laptop.
  8. Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: 步骤 8 中的图像 1,3 Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: 步骤 8 中的图像 2,3 Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: 步骤 8 中的图像 3,3
    • After the fan has been removed, lift the hinge so as to get access to the parts below it.
    • Remove the the black colored cable that is now exposed.
  9. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 9 中的图像 1,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 9 中的图像 2,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 9 中的图像 3,3
    • Remove the 7 mm Phillips #0 screw on the other hinge.
    • Remove the 3.1 mm Phillips #0 screw on the the same hinge.
    • Lift the hinge up and towards you.
  10. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 10 中的图像 2,2
    • Pull out the wide cable to reveal the components underneath.
  11. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 11 中的图像 1,2 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 11 中的图像 2,2
    • Remove the 3.1 mm Phillips #0 screw holding the chip in place.
    • Pull out the chip.
  12. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 12 中的图像 1,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 12 中的图像 2,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 12 中的图像 3,3
    • Hold the cable that is to be removed.
    • Use an iFixit opening tool to push down on the white protrusion of cable connector.
    • Now you can pull out the cable.
  13. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 13 中的图像 1,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 13 中的图像 2,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 13 中的图像 3,3
    • Pivot and lift up the monitor and separate it from the base of the laptop.
  14. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 14 中的图像 1,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 14 中的图像 2,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 14 中的图像 3,3
    • Use an iFixit opening tool to separate the two halves of the bezel starting at both the plastic hinges.
    • Use the metal spudger to separate the rest of the bezel.
    • Be careful not to scratch the screen with the metal spudger.
    • You may hear some sounds as the clips on the bezel disconnect from the back cover. This is normal.
  15. Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: 步骤 15 中的图像 1,3 Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: 步骤 15 中的图像 2,3 Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: 步骤 15 中的图像 3,3
    • Remove the three 4.1 mm Phillips #0 screws attaching each hinge to the screen.
  16. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 16 中的图像 1,2 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 16 中的图像 2,2
    • Remove the two 3.1 mm Phillips #0 screws at the top of the screen.
  17. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 17 中的图像 1,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 17 中的图像 2,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 17 中的图像 3,3
    • Pull up on and turn over the screen to expose the wire connecting the webcam to the screen.
    • Be careful not to pull up on the screen too far and damage the wire.
  18. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 18 中的图像 1,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 18 中的图像 2,3 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 18 中的图像 3,3
    • Once the screen has been detached and turned over, remove the webcam from its place on the bezel.
  19. Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 19 中的图像 1,2 Toshiba Satellite C55-B5302 Webcam Replacement: 步骤 19 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Carefully, take off the tape connecting the webcam to the circuit board using a set of tweezers.
    • Once the tape has been removed, you can disconnect the webcam from the wire completely.
结论
2等其他人完成本指南。
David Browning
于03/25/19注册
310 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Henning Spring 2019 IUPUI, Team S1-G3, Henning Spring 2019 的会员
IUPUI-HENNING-S19S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,535
