跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
How to replace the RAM on a Toshiba Satellite C55-B5200 laptop.
  1. Turn the laptop off and remove all sources of power.
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Pull the battery out of the laptop.
    • Pull the battery out of the laptop.
  3. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  4. Flex the metal retaining clips on the side of the RAM away from one another.
    • Flex the metal retaining clips on the side of the RAM away from one another.
    • If done correctly, the RAM will pop out of its lock.
  5. Pull the RAM out of the socket to remove.
    • Pull the RAM out of the socket to remove.
结论
2等其他人完成本指南。
Pablo Andrade
于2018年02月14日注册
984 信誉积分
创作了7篇指南
团队
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 的会员
USFT-NANCE-S18S3G1
4 名成员
创作了8篇指南
So the complete bottom panel doesn’t need to be removed to access the memory? The bottom panel that is held in place by another 8 screws?
Andrew Kling - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 3
过去的30天: 14
总计 432
