跳转到主内容
Toshiba Satellite C55-B5200 RAM Replacement
你所需要的
  1. Toshiba Satellite C55-B5200 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 RAM Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • Flex the metal retaining clips on the side of the RAM away from one another.
    • If done correctly, the RAM will pop out of its lock.
  4. Toshiba Satellite C55-B5200 RAM Replacement: 步骤 4 中的图像 1,1
    • Pull the RAM out of the socket to remove.
结论
3等其他人完成本指南。
Pablo Andrade
于02/14/18注册
1,081 声望
创作了7篇指南
团队
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 的会员
USFT-NANCE-S18S3G1
4 名成员
创作了22篇指南
一条评论
So the complete bottom panel doesn’t need to be removed to access the memory? The bottom panel that is held in place by another 8 screws?
Andrew Kling - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 1,120
