跳转到主内容
Toshiba Satellite C55-B5200 Optical Disk Drive Replacement
你所需要的
  1. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement, Optical Disk Drive: 步骤 3 中的图像 1,1
    • Make sure device is turned off and unplugged
    • Failure to do so could result in electric shock
    • Use J0 Philips Head Screwdrivers to remove 13, 6.6 mm screws on back of device
  4. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: 步骤 4 中的图像 3,3
    • Remove the remaining two, 6.6 mm screws to remove the battery
    • Use a plastic opening tool to lift and open the back
  5. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: 步骤 5 中的图像 1,1
    • Lift and pull out disk drive
结论
另外一个人完成了本指南。
Pablo Andrade
于02/14/18注册
1,081 声望
创作了7篇指南
团队
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 的会员
USFT-NANCE-S18S3G1
4 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 16
总计 721
