当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Disconnect the wires from the motherboard.
Lift and remove the disk drive.
Lift and remove the hard drive.
Use a plastic opening tool to unlatch the keyboard from the device
Lift the keyboard off the laptop, careful of the IDE ribbon cable
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
