跳转到主内容
Toshiba Satellite C55-B5200 Hard Disk Drive Replacement
你所需要的
  1. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: 步骤 3 中的图像 1,3 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: 步骤 3 中的图像 2,3 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: 步骤 3 中的图像 3,3
    • Remove the two 4.6mm Phillips #0 screws from disk drive.
    • Lift the disk drive and pull out to remove.
结论
5等其他人完成本指南。
Pablo Andrade
于02/14/18注册
1,081 声望
创作了7篇指南
团队
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 的会员
USFT-NANCE-S18S3G1
4 名成员
创作了22篇指南
一条评论
Pablo, you didn’t mention that you must remove all the screws to get at the hard drive. What a pain. Other satellites have compartments the c55 that i have you must take every screw out as the back is one piece. Thanks for the instructions.
stevesd619 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 4,474
