跳转到主内容
简介
A guide on how to replace the fan on your Toshiba Satellite C55-B5200 laptop.
  1. Turn the laptop off and remove all sources of power.
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  3. Pull the battery out of the laptop.
    • Pull the battery out of the laptop.
  4. Remove the single 4.6mm Phillips #0 screw securing the fan. Use a pair of tweezers to unplug the fan from the motherboard. Pull the fan out.
    • Remove the single 4.6mm Phillips #0 screw securing the fan.
    • Use a pair of tweezers to unplug the fan from the motherboard.
    • Pull the fan out.
结论
另外一个人完成了本指南。
Pablo Andrade
于2018年02月14日注册
939 信誉积分
创作了7篇指南
团队
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 的会员
USFT-NANCE-S18S3G1
4 名成员
创作了8篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 6
过去的30天: 11
总计 277
