跳转到主内容
Toshiba Satellite C55-A5310 Optical Drive Replacement
你所需要的
  1. Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: 步骤 2 中的图像 1,2 Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: 步骤 2 中的图像 2,2
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Optical Drive Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C55-A5310 Optical Drive Replacement: 步骤 4 中的图像 2,2
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Optical Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C55-A5310 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
结论
Kari Rodgers
于02/08/18注册
482 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 16
总计 332
