跳转到主内容
Toshiba Satellite C55-A5310 Fan Replacement
你所需要的
  1. Toshiba Satellite C55-A5310 Fan Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite C55-A5310 Fan Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite C55-A5310 Fan Replacement, Battery: 步骤 1 中的图像 3,3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: 步骤 2 中的图像 1,2 Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: 步骤 2 中的图像 2,2
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 3 中的图像 1,1
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C55-A5310 Fan Replacement: 步骤 4 中的图像 2,2
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C55-A5310 Fan Replacement: 步骤 5 中的图像 2,2
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
  6. Toshiba Satellite C55-A5310 Fan Replacement, Fan: 步骤 6 中的图像 1,2 Toshiba Satellite C55-A5310 Fan Replacement, Fan: 步骤 6 中的图像 2,2
    • Take a nylon spudger and push the prongs so that it releases the RAM.
  7. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Once the RAM has lifted, use tweezers or fingers to pull it out.
  8. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite C55-A5310 Fan Replacement: 步骤 8 中的图像 2,2
    • Remove the single .5mm JIS #000 screw.
  9. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 9 中的图像 1,1
    • Use the plastic opening tool to remove the keyboard from the laptop.
  10. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite C55-A5310 Fan Replacement: 步骤 10 中的图像 2,2
    • Once the keyboard is popped out, use a spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
  11. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 11 中的图像 1,1
    • Remove thirteen JIS #000 11mm screws.
  12. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 12 中的图像 1,2 Toshiba Satellite C55-A5310 Fan Replacement: 步骤 12 中的图像 2,2
    • Use a nylon spudger tool to lift up on all sides.
    • Once the panel has been loosened it will pop off.
  13. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 13 中的图像 1,1
    • Remove five 11mm JIS #000 screws.
  14. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 14 中的图像 1,3 Toshiba Satellite C55-A5310 Fan Replacement: 步骤 14 中的图像 2,3 Toshiba Satellite C55-A5310 Fan Replacement: 步骤 14 中的图像 3,3
    • Remove the four wires with tweezers.
    • Remove wires gently to avoid damaging them.
  15. Toshiba Satellite C55-A5310 Fan Replacement: 步骤 15 中的图像 1,1
    • Lift from corresponding sides of the fan and it'll pop right out.
结论
Robin
于02/08/18注册
181 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 555
