跳转到主内容
Toshiba Satellite C55-A5302 Screen Replacement
你所需要的
  1. Toshiba Satellite C55-A5302 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 Screen Replacement: 步骤 2 中的图像 1,1
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 Screen Replacement: 步骤 3 中的图像 1,1
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 Screen Replacement, Screen: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the screw covers in the lower corners of the screen.
  5. Toshiba Satellite C55-A5302 Screen Replacement: 步骤 5 中的图像 1,1
    • Use the Phillips #1 screwdriver to unscrew the two screws in the lower corners of the screen.
  6. Toshiba Satellite C55-A5302 Screen Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite C55-A5302 Screen Replacement: 步骤 6 中的图像 2,2
    • Start popping off the cover all the way around the screen until it comes off.
  7. Toshiba Satellite C55-A5302 Screen Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite C55-A5302 Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the two screws in the top corners with a Phillips #1 screwdriver. The screen will pop forward after removing the two screws.
    • Using the same Phillips #1 screwdriver, remove the three screws on the side of screen frame.
  8. Toshiba Satellite C55-A5302 Screen Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite C55-A5302 Screen Replacement: 步骤 8 中的图像 2,2
    • On the back of screen, lift up the plastic film and screen connector. Pop out the connector, and gently remove the screen.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 26
总计 718
