跳转到主内容
Toshiba Satellite C55-A5302 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite C55-A5302 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
  5. Toshiba Satellite C55-A5302 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the middle plastic cover to expose the hard drive.
  6. Toshiba Satellite C55-A5302 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
  7. Toshiba Satellite C55-A5302 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the three screws using the Phillips #1 screwdriver.
    • Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 661
