跳转到主内容
Toshiba Satellite C55-A5300 CD Drive Replacement
你所需要的
  1. Toshiba Satellite C55-A5300 CD Drive Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite C55-A5300 CD Drive Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite C55-A5300 CD Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 CD Drive Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite C55-A5300 CD Drive Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite C55-A5300 CD Drive Replacement: 步骤 2 中的图像 3,3
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
  3. Toshiba Satellite C55-A5300 CD Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Unscrew the screw on the back panel of the laptop covering the hard drive.
  4. Toshiba Satellite C55-A5300 CD Drive Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tools to remove the panel.
  5. Toshiba Satellite C55-A5300 CD Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the screw next to the hard drive using the PH1 screwdriver.
  6. Toshiba Satellite C55-A5300 CD Drive Replacement: 步骤 6 中的图像 1,1
    • Pull the silver tab connected to the hard drive up to take it out.
  7. Toshiba Satellite C55-A5300 CD Drive Replacement, CD Drive: 步骤 7 中的图像 1,1
    • Remove the screw to the top right of the hard drive using the PH1 screwdriver.
  8. Toshiba Satellite C55-A5300 CD Drive Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opening tool to wedge between the CD Drive and the laptop casing and gently pull it out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 258
