跳转到主内容
Toshiba Satellite C55-A5300 Battery Replacement
你所需要的
  1. Toshiba Satellite C55-A5300 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite C55-A5300 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite C55-A5300 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Battery Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite C55-A5300 Battery Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite C55-A5300 Battery Replacement: 步骤 2 中的图像 3,3
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 390
