跳转到主内容
Toshiba Satellite C55-A5286 Optical Drive Replacement
你所需要的
  1. Toshiba Satellite C55-A5286 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Unplug the AC adapter and all other auxiliary components from the laptop
  2. Toshiba Satellite C55-A5286 Optical Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C55-A5286 Optical Drive Replacement: 步骤 2 中的图像 2,2
    • Unscrew the only screw (5 mm) that is holding on the removable back panel and remove the back panel.
  3. Toshiba Satellite C55-A5286 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the two 5-mm screws near the disk drive on the back panel. These two screws are above and below the manufacturer’s sticker.
  4. Toshiba Satellite C55-A5286 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Under the back panel, remove the 4-mm screw holding the disk drive in place.
  5. Toshiba Satellite C55-A5286 Optical Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C55-A5286 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Carefully slide the optical drive out of its place in the laptop.
结论
2等其他人完成本指南。
Nicole Zellers
于11/06/18注册
265 声望
创作了2篇指南
团队
IUPUI, Team S1-G5, Hovde Fall 2018 IUPUI, Team S1-G5, Hovde Fall 2018 的会员
IUPUI-HOVDE-F18S1G5
2 名成员
创作了9篇指南
一条评论
Not a medium effort at all - very easy.
…although, I did have to use an iFixt It needle-nose tweezer to pull the middle 5mm screw out after it was unscrewed - it would not fall out nor did it cling to the screwdriver.
William Totman - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 302
