跳转到主内容
Toshiba Satellite C55-A5100 Optical Drive Replacement
你所需要的
  1. Toshiba Satellite C55-A5100 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 1,3 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 2,3 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 3,3
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the disc drive from the device.
结论
3等其他人完成本指南。
一条评论
Any idea of how tall the drive is? Is it 12.7mm or 9.5mm tall?
Luis Alejandro Araúz - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 12
总计 336
