跳转到主内容
Toshiba Satellite C55-A5100 Keyboard Replacement
你所需要的
  1. Toshiba Satellite C55-A5100 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • On the back of the laptop, remove the 6mm Phillips #1 screw. This screw is attached to the keyboard.
  4. Toshiba Satellite C55-A5100 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Looking at the keyboard, locate the eight clips that hold it in place.
  5. Toshiba Satellite C55-A5100 Keyboard Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C55-A5100 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to slide the clips back, releasing the keyboard.
    • As you release the clips, use the plastic opening tool to lift keyboard above the clips.
  6. Toshiba Satellite C55-A5100 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Once the keyboard is released from the clips you should be able to lift it up, exposing the wire connecting it to the laptop.
    • The keyboard will slide out of the clips on the top.
  7. Toshiba Satellite C55-A5100 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Using your fingers, slowly pull the wire out of its connection.
    • The keyboard is now disconnected.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 901
