跳转到主内容
Toshiba Satellite C55-A5100 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite C55-A5100 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,3 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,3 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  5. Toshiba Satellite C55-A5100 Hard Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C55-A5100 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 27
总计 921
