跳转到主内容
Toshiba Satellite C50D-A Optical Drive Replacement
你所需要的
  1. Toshiba Satellite C50D-A Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Click button 1 to the unlocked position.
    • This button will have a 1 by it.
  2. Toshiba Satellite C50D-A Optical Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C50D-A Optical Drive Replacement: 步骤 2 中的图像 2,2
    • Push and hold button 2 to the left.
    • As you push button 2 to the left position, simultaneously lift up the battery pack.
    • This button will have a 2 by it.
  3. Toshiba Satellite C50D-A Optical Drive Replacement, Lower Case: 步骤 3 中的图像 1,2 Toshiba Satellite C50D-A Optical Drive Replacement, Lower Case: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
  4. Toshiba Satellite C50D-A Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the one 2.5mm Phillips #1 middle plate screw.
  5. Toshiba Satellite C50D-A Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Lift up the middle vent panel.
    • Set the panel to the side.
  6. Toshiba Satellite C50D-A Optical Drive Replacement: 步骤 6 中的图像 1,3 Toshiba Satellite C50D-A Optical Drive Replacement: 步骤 6 中的图像 2,3 Toshiba Satellite C50D-A Optical Drive Replacement: 步骤 6 中的图像 3,3
    • Using the plastic opening tool, remove the outer panel and set to the side.
    • Be careful not to break the back of the computer.
  7. Toshiba Satellite C50D-A Optical Drive Replacement, Optical Drive: 步骤 7 中的图像 1,1
    • Locate the opticaldrive and find where it is slotted into the motherboard.
    • Be careful not to break the attachment site.
  8. Toshiba Satellite C50D-A Optical Drive Replacement: 步骤 8 中的图像 1,1
    • Gently lift up the optical drive at a slight angle, and pull it towards you to remove it.
结论
一条评论
This is an awful guide - it does not tell you that there are another 6 or more screws under the keyboard - this is bad.
Books2Africa Tech Team - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 17
总计 891
