跳转到主内容
Toshiba Satellite A85-S107 15" Wireless Card Replacement
你所需要的
  1. Toshiba Satellite A85-S107 15" Wireless Card Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right.
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite A85-S107 15" Wireless Card Replacement: 步骤 4 中的图像 2,2
    • Loosen this 5 mm Phillips #0 screw found in the center of the lower case.
    • The screw will not come out completely, it will stay connected to the center plate.
  5. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Remove the center plate by lifting it and sliding it to the right.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that the screw is loose before attempting again.
  6. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 步骤 6 中的图像 1,1
    • The computer should be open with many of the internal components shown. You can now access the RAM, and wireless card.
  7. Toshiba Satellite A85-S107 15" Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 1,2 Toshiba Satellite A85-S107 15" Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 2,2
    • Carefully pull the white auxiliary wire out of its socket on the wireless card.
    • Now repeat this step with the black auxiliary wire.
    • Be careful when removing the wires, as the wireless card and the wires are delicate.
  8. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite A85-S107 15" Wireless Card Replacement: 步骤 8 中的图像 2,2
    • Push the two black tabs, located on the sides of the card, away from the card.
    • The right side of the wireless card should now pop out of its holder.
    • Pull the wireless card out by lifting it from the dock and sliding it towards the right.
结论
Travis
于04/13/13注册
31 声望
创作了5篇指南
团队
Cal Poly, Team 10-38, Amido Spring 2013 Cal Poly, Team 10-38, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G38
4 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 755
