跳转到主内容
Toshiba Satellite A85-S107 15" Battery Replacement
你所需要的
  1. Toshiba Satellite A85-S107 15" Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Battery Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Battery Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite A85-S107 15" Battery Replacement: 步骤 3 中的图像 2,2
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
结论
Travis
于04/13/13注册
31 声望
创作了5篇指南
团队
Cal Poly, Team 10-38, Amido Spring 2013 Cal Poly, Team 10-38, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G38
4 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 549
