跳转到主内容
Toshiba Satellite A75-S226 Fans Replacement
你所需要的
  1. Toshiba Satellite A75-S226 Fans Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure battery-lock is in the unlock position.
    • Slide button to the left.
  2. Toshiba Satellite A75-S226 Fans Replacement: 步骤 2 中的图像 1,1
    • Lift battery out of the computer.
  3. Toshiba Satellite A75-S226 Fans Replacement, Optical Drive: 步骤 3 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement, Optical Drive: 步骤 3 中的图像 2,2
    • Remove the two 5.62 mm screws from the optical drive cover.
  4. Toshiba Satellite A75-S226 Fans Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement: 步骤 4 中的图像 2,2
    • Remove the optical drive cover.
    • A plastic opening tool or a fingernail may be helpful in lifting it from its groove.
  5. Toshiba Satellite A75-S226 Fans Replacement: 步骤 5 中的图像 1,1
    • Using the inset divot, push the optical drive out of the laptop to remove.
  6. Toshiba Satellite A75-S226 Fans Replacement, CD Drive: 步骤 6 中的图像 1,3 Toshiba Satellite A75-S226 Fans Replacement, CD Drive: 步骤 6 中的图像 2,3 Toshiba Satellite A75-S226 Fans Replacement, CD Drive: 步骤 6 中的图像 3,3
    • Remove the 8.6 mm screw.
  7. Toshiba Satellite A75-S226 Fans Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite A75-S226 Fans Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite A75-S226 Fans Replacement: 步骤 7 中的图像 3,3
    • Push the bottom left corner of the CD Drive until the drive protrudes from the case.
    • When a good amount of the CD Drive is showing on the right side, gently pull it out completely.
  8. Toshiba Satellite A75-S226 Fans Replacement, Wi-Fi/Memory Cover: 步骤 8 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement, Wi-Fi/Memory Cover: 步骤 8 中的图像 2,2
    • Remove the 5.75 mm screw from the cover panel.
    • Turn the laptop over with the screen facing down.
  9. Toshiba Satellite A75-S226 Fans Replacement: 步骤 9 中的图像 1,1
    • Lift up the cover panel using a plastic opening tool.
  10. Toshiba Satellite A75-S226 Fans Replacement, Wi-Fi Card: 步骤 10 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement, Wi-Fi Card: 步骤 10 中的图像 2,2
    • Remove the 5.64 mm screw from the bottom of the crossing bar.
    • Remove the crossing bar.
  11. Toshiba Satellite A75-S226 Fans Replacement: 步骤 11 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement: 步骤 11 中的图像 2,2
    • Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card.
    • Note that the black wire is connected to the port that is labeled main.
  12. Toshiba Satellite A75-S226 Fans Replacement: 步骤 12 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement: 步骤 12 中的图像 2,2
    • Use fingers to push the clips away from memory card.
  13. Toshiba Satellite A75-S226 Fans Replacement: 步骤 13 中的图像 1,1
    • Use fingers to remove the Wi-Fi card.
  14. Toshiba Satellite A75-S226 Fans Replacement, Keyboard: 步骤 14 中的图像 1,3 Toshiba Satellite A75-S226 Fans Replacement, Keyboard: 步骤 14 中的图像 2,3 Toshiba Satellite A75-S226 Fans Replacement, Keyboard: 步骤 14 中的图像 3,3
    • Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
    • It may be helpful to first pry at the rear of the hinge covers (not shown) to release them. Then Insert the plastic opening tool underneath the top panel's sides and then front edge.
  15. Toshiba Satellite A75-S226 Fans Replacement: 步骤 15 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement: 步骤 15 中的图像 2,2
    • Remove the top panel by popping the panel out the top left socket, then do the same with the right side.
  16. Toshiba Satellite A75-S226 Fans Replacement: 步骤 16 中的图像 1,3 Toshiba Satellite A75-S226 Fans Replacement: 步骤 16 中的图像 2,3 Toshiba Satellite A75-S226 Fans Replacement: 步骤 16 中的图像 3,3
    • Remove the two 3.67 mm screws from the top corners of the keyboard.
  17. Toshiba Satellite A75-S226 Fans Replacement: 步骤 17 中的图像 1,1
    • Use fingers to lift up the keyboard from the top.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  18. Toshiba Satellite A75-S226 Fans Replacement: 步骤 18 中的图像 1,3 Toshiba Satellite A75-S226 Fans Replacement: 步骤 18 中的图像 2,3 Toshiba Satellite A75-S226 Fans Replacement: 步骤 18 中的图像 3,3
    • Remove the cable connecting the keyboard with the motherboard.
    • Be aware of the locking tabs on each side of the ribbon-cable connector—they slide back about 2mm to free the cable.
    • Lift up and remove the keyboard.
  19. Toshiba Satellite A75-S226 Fans Replacement, Display Assembly: 步骤 19 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement, Display Assembly: 步骤 19 中的图像 2,2
    • Remove the 3.76mm screw from the ground wire.
  20. Toshiba Satellite A75-S226 Fans Replacement: 步骤 20 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement: 步骤 20 中的图像 2,2
    • Use the plastic opening tool to remove the wire.
  21. Toshiba Satellite A75-S226 Fans Replacement: 步骤 21 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement: 步骤 21 中的图像 2,2
    • Gently pull the black and white wires out of the upper case.
    • Do not pull the wire too much, or you can damage the wire.
  22. Toshiba Satellite A75-S226 Fans Replacement: 步骤 22 中的图像 1,1
    • Remove the 8.6 mm screw on left side of upper case.
  23. Toshiba Satellite A75-S226 Fans Replacement: 步骤 23 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement: 步骤 23 中的图像 2,2
    • Remove two 8.6 mm screws on the back corners of the laptop.
  24. Toshiba Satellite A75-S226 Fans Replacement: 步骤 24 中的图像 1,1
    • Lift up the display assembly to remove it.
    one of the 14 screws identified in the diagram of step 25 was previously removed with the CD drive
    Steve - 回复
  25. Toshiba Satellite A75-S226 Fans Replacement, Upper Case: 步骤 25 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement, Upper Case: 步骤 25 中的图像 2,2
    • Use the Phillips screwdriver to remove the two 3.7 mm screws from the battery compartment.
    • Then remove the fourteen 8.6 mm screws from the bottom of the case.
    There is one more not circled on the top left of this photo, left of the rubber foot.
    Barron Chung - 回复
  26. Toshiba Satellite A75-S226 Fans Replacement: 步骤 26 中的图像 1,1
    • Use the screwdriver to remove six 8.6 mm screws from the top of the case.
    On mine the leftmost screw here was 3mm.
    Barron Chung - 回复
  27. Toshiba Satellite A75-S226 Fans Replacement: 步骤 27 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement: 步骤 27 中的图像 2,2
    • Use the plastic opening tool to remove the two speaker wire connectors and the trackpad connector from the motherboard.
  28. Toshiba Satellite A75-S226 Fans Replacement: 步骤 28 中的图像 1,1
    • With the plastic opening tool, pry around the entire laptop to separate the upper case.
  29. Toshiba Satellite A75-S226 Fans Replacement: 步骤 29 中的图像 1,1
    • Lift up the upper case to remove.
  30. Toshiba Satellite A75-S226 Fans Replacement, Motherboard: 步骤 30 中的图像 1,1
    • Using the Phillips Screwdriver, remove the two 8.6 mm screws from the front edge of the motherboard.
  31. Toshiba Satellite A75-S226 Fans Replacement: 步骤 31 中的图像 1,1
    • Remove the four screws holding the ports to the rear panel using the 3/16" Wrench.
  32. Toshiba Satellite A75-S226 Fans Replacement: 步骤 32 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement: 步骤 32 中的图像 2,2
    • Lift up on the front edge of the motherboard while gently prying the case away from the ports on the right side of the computer.
    • Repeat with the left side.
    • There is a button for the card slot on the left side of the computer that may pop out if pressed. This button must be held in place while removing the motherboard.
  33. Toshiba Satellite A75-S226 Fans Replacement: 步骤 33 中的图像 1,1
    • Lift the motherboard's front edge up and then slide it forward.
  34. Toshiba Satellite A75-S226 Fans Replacement, Fans: 步骤 34 中的图像 1,3 Toshiba Satellite A75-S226 Fans Replacement, Fans: 步骤 34 中的图像 2,3 Toshiba Satellite A75-S226 Fans Replacement, Fans: 步骤 34 中的图像 3,3
    • Remove cables connecting the fans with the motherboard.
  35. Toshiba Satellite A75-S226 Fans Replacement: 步骤 35 中的图像 1,2 Toshiba Satellite A75-S226 Fans Replacement: 步骤 35 中的图像 2,2
    • Turn over the motherboard.
    • Remove the four silver screws with a Phillips screwdriver.
  36. Toshiba Satellite A75-S226 Fans Replacement: 步骤 36 中的图像 1,1
    • Lift the fans up to remove them from the motherboard.
结论
5等其他人完成本指南。
Garrett Gudgel
于10/05/10注册
763 声望
创作了13篇指南
团队
Cal Poly, Team 4-43, Amido Fall 2010 Cal Poly, Team 4-43, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G43
5 名成员
创作了39篇指南
2条评论
Thanks Garrett...
Your time and effort in putting this guide together is much appreciated (and helpful!)
Rick
Rick Cordingley - 回复
I found this guide to be very helpful, well written and easy to follow.
Close up pics of any connectors, wires and cables that are disconnected help me a lot in that many of my projects have been previously attempted by others who have damaged or wrongly re-assembled the items.
Steve - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 5,245
