跳转到主内容
Toshiba Satellite A665-S5170 RAM Replacement
你所需要的
  1. Toshiba Satellite A665-S5170 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Turn your computer upside down so that the bottom of your laptop is facing up.
    • Position your laptop so that you are able to read the words printed on the labels on the bottom of the computer from left to right.
    • Using a Phillips head 0 screw driver, remove the 2mm Phillips head screw at the bottom edge of the RAM panel (located in the center of the bottom of the laptop) by rotating the screw counterclockwise.
  2. Toshiba Satellite A665-S5170 RAM Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite A665-S5170 RAM Replacement: 步骤 2 中的图像 2,2
    • Insert something thin, such as your fingernail or a credit card, into the slot at the bottom edge of the RAM panel.
    • Pull up with your hand until the cover of the RAM panel pops out of place and can be removed completely.
  3. Toshiba Satellite A665-S5170 RAM Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite A665-S5170 RAM Replacement: 步骤 3 中的图像 2,2
    • With your thumbs, press down on the small silver clamps on the left and right edges of the upper green RAM chip until the clamps release the chip.
    • When the chip is released, it will pop up and stick out at a 45 degree angle from the computer.
  4. Toshiba Satellite A665-S5170 RAM Replacement: 步骤 4 中的图像 1,1
    • Remove the upper RAM chip from its socket by gently gripping the left and right edges with your fingers and pulling the chip towards your body until it slides completely free of the computer.
  5. Toshiba Satellite A665-S5170 RAM Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite A665-S5170 RAM Replacement: 步骤 5 中的图像 2,2
    • With your thumbs, press down on the small silver clamps on the left and right edges of the lower green RAM chip until the clamps release the chip.
  6. Toshiba Satellite A665-S5170 RAM Replacement: 步骤 6 中的图像 1,1
    • Remove the lower RAM chip from its socket by gently gripping the left and right edges with your fingers and pulling the chip towards your body until it slides completely free of the computer.
结论
另外一个人完成了本指南。
Will Peterson
于10/31/16注册
121 声望
撰写一个指南
团队
Baylor, Team 4-5, Williams Fall 2016 Baylor, Team 4-5, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 12
总计 797
