跳转到主内容
Toshiba Satellite A665-S5170 Key Replacement
你所需要的
  1. Toshiba Satellite A665-S5170 Key Replacement, Key: 步骤 1 中的图像 1,2 Toshiba Satellite A665-S5170 Key Replacement, Key: 步骤 1 中的图像 2,2
    • Insert something thin, such as your fingernail or a credit card, beneath the corner of the key cap (the part of the key that is normally visible).
    • Pull up on the key cap until it pops free of the keyboard.
  2. Toshiba Satellite A665-S5170 Key Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite A665-S5170 Key Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite A665-S5170 Key Replacement: 步骤 2 中的图像 3,3
    • Grip the upper edge of the key pad--the white hinge beneath the key cap of the key--with your flat nose pliers.
    • With the edge of the key pad pinched firmly in your pliers, gently pull up with your pliers until the top left and right corners of the key pad pop out of place.
    • Still holding the key pad with your pliers, slide the key pad towards the bottom of the key panel until the bottom of the key pad slides out of its hinge.
    • Lift the key pad fully from the computer with your pliers.
结论
To reassemble your device, follow these instructions in reverse order. Be sure to read the notes when reassembling the device.
Dominic Rizzo
于10/30/16注册
179 声望
撰写一个指南
团队
Baylor, Team 4-5, Williams Fall 2016 Baylor, Team 4-5, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 773
