跳转到主内容
Toshiba Satellite A665-S5170 Battery Replacement
你所需要的
  1. Toshiba Satellite A665-S5170 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite A665-S5170 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the computer upside-down so that the bottom of the laptop is facing up.
    • Position the computer so that you are able to read the words on the labels on the bottom of the laptop from left to right.
    • Using the tip of your finger, slide the right clasp of the battery panel horizontally to the right until it locks into place.
  2. Toshiba Satellite A665-S5170 Battery Replacement: 步骤 2 中的图像 1,1
    • Slide the left clasp of the battery panel horizontally to the left, and hold it in place.
    • You will have to continue holding the left clasp of the battery panel in place for future steps in order to remove the battery.
  3. Toshiba Satellite A665-S5170 Battery Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite A665-S5170 Battery Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite A665-S5170 Battery Replacement: 步骤 3 中的图像 3,3
    • While continuing to hold the left clasp of the battery panel in place, slide out the old battery by pulling it towards you.
结论
2等其他人完成本指南。
Chelsea Teague
于10/30/16注册
385 声望
创作了2篇指南
团队
Baylor, Team 4-5, Williams Fall 2016 Baylor, Team 4-5, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 1,163
