简介
This replacement guide is to walk you through a RAM replacement on your Toshiba Satellite A660-ST3NX2X. Before starting this replacement, make sure you have a replacement RAM stick that is made for this computer and model. Also, make sure the computer is powered off and completely shut down before completing this replacement.
你所需要的
Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
Use a J00 bit to unscrew the single 4mm screw that leads to the RAM Memory compartment.
即将完成!
结论
