跳转到主内容
Toshiba Satellite A660-ST3NX2X RAM Replacement
你所需要的
  1. Toshiba Satellite A660-ST3NX2X RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 2 中的图像 2,2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 3 中的图像 3,3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X RAM Replacement, RAM Memory: 步骤 4 中的图像 1,2 Toshiba Satellite A660-ST3NX2X RAM Replacement, RAM Memory: 步骤 4 中的图像 2,2
    • Use a J00 bit to unscrew the single 4mm screw that leads to the RAM Memory compartment.
  5. Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 5 中的图像 1,1
    • Open the hatch that holds the RAM cards.
  6. Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 6 中的图像 2,2
    • Pull apart the two metal tabs that are holding the RAM cards in place.
    • You will feel the card pop up from its held position, indicating it can safely be pulled out.
  7. Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 7 中的图像 2,2
    • Pull out the top RAM card.
  8. Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite A660-ST3NX2X RAM Replacement: 步骤 8 中的图像 2,2
    • Use tabs on the sides of the bottom RAM card to release the RAM card.
    • Remove the bottom RAM card, just as the top RAM card was removed.
结论
Cassie Pickett
于03/20/17注册
201 声望
创作了2篇指南
团队
Texas Tech, Team S8-G1, Bennett Spring 2017 Texas Tech, Team S8-G1, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G1
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 401
