跳转到主内容
Toshiba Satellite A65-S126 Speaker Replacement
你所需要的
  1. Toshiba Satellite A65-S126 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Speaker Replacement: 步骤 2 中的图像 1,1
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Speaker Replacement, Upper Assembly: 步骤 3 中的图像 1,1
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Speaker Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite A65-S126 Speaker Replacement: 步骤 5 中的图像 2,2
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Speaker Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Speaker Replacement, Speaker: 步骤 9 中的图像 1,2 Toshiba Satellite A65-S126 Speaker Replacement, Speaker: 步骤 9 中的图像 2,2
    • Locate the plug for the speaker wires on the bottom of the laptop.
  10. Toshiba Satellite A65-S126 Speaker Replacement: 步骤 10 中的图像 1,1
    • Unplug the speaker wire connector.
  11. Toshiba Satellite A65-S126 Speaker Replacement: 步骤 11 中的图像 1,1
    • Remove the speakers by sliding them straight up. They should slide out with ease.
结论
Cole Uhland
于09/30/13注册
216 声望
创作了2篇指南
团队
Cal Poly, Team 14-8, Forte Fall 2013 Cal Poly, Team 14-8, Forte Fall 2013 的会员
CPSU-FORTE-F13S14G8
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 525
