跳转到主内容
Toshiba Satellite A305-S6848 LCD Screen Replacement
你所需要的
  1. Toshiba Satellite A305-S6848 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,2 Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 2,2
    • Remove the 6 rubber tabs on the housing using the metal spudger.
  5. Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Remove the six 5.8 mm screws using the Phillip's #0 screwdriver.
  6. Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Pry out plastic housing on all sides.
  7. Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Pry out the bottom left and right locking pieces of the plastic housing with the metal spudger.
  8. Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the four 5.8 mm screws using the Phillip's #0 screwdriver.
  9. Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the eight 6.5 mm screws on the left and right sides of the screen using the Phillip's #0 screwdriver.
  10. Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 10 中的图像 2,2
    • Pull the screen down.
    • Pull off tape and take our video connector.
  11. Toshiba Satellite A305-S6848 LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Remove cold cathode fluorescent light bulb connector.
结论
Joshua E Hong
于11/06/17注册
449 声望
创作了4篇指南
团队
Baylor, Team S8-G1, Johnson Fall 2017 Baylor, Team S8-G1, Johnson Fall 2017 的会员
BU-JOHNSON-F17S8G1
2 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 517
