跳转到主内容
Toshiba Satellite A305-S6848 Keyboard Replacement
你所需要的
  1. Toshiba Satellite A305-S6848 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • The keyboard is held in by a locking strip between the screen and the keyboard.
  5. Toshiba Satellite A305-S6848 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Use the metal spudger to pry out the right portion of the locking piece just above the DEL key.
  6. Toshiba Satellite A305-S6848 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Use your hand to take out locking strip from the right portion that was pried out.
  7. Toshiba Satellite A305-S6848 Keyboard Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite A305-S6848 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Use the Phillip's #0 screwdriver to take out the two 5.8 mm Phillip's #0 screws from the top right and left corners of the keyboard.
  8. Toshiba Satellite A305-S6848 Keyboard Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite A305-S6848 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Lift the keyboard up slightly. Use caution as the keyboard ribbon cable is still attached below the keyboard.
    • Disconnect the keyboard by flipping the locking clip upwards.
结论
Joshua E Hong
于11/06/17注册
449 声望
创作了4篇指南
团队
Baylor, Team S8-G1, Johnson Fall 2017 Baylor, Team S8-G1, Johnson Fall 2017 的会员
BU-JOHNSON-F17S8G1
2 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 10
总计 571
