跳转到主内容
Toshiba Satellite A215-S7425 Optical Drive Replacement
你所需要的
  1. Toshiba Satellite A215-S7425 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Optical Drive Replacement, RAM: 步骤 4 中的图像 1,1
    • Locate the RAM vented plastic cover in the center of the device.
  5. Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
  6. Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 6 中的图像 1,3 Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 6 中的图像 2,3 Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Locate 2 metal pinchers on either side of the 1st RAM stick.
    • Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
    • The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
    • The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
  7. Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 7 中的图像 3,3
    • To remove the 2nd RAM stick, repeat previous steps.
    • You will be unable to remove 2nd RAM stick if the first one is not removed first.
  8. Toshiba Satellite A215-S7425 Optical Drive Replacement, Optical Drive: 步骤 8 中的图像 1,1
    • Locate and remove 1 Phillips 4.2 mm size screw along right side of RAM container.
    • Tweezers may be needed to lift out the screw.
  9. Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite A215-S7425 Optical Drive Replacement: 步骤 9 中的图像 2,2
    • Push down metal rod until optical drive pops out from its container on the side of the device.
    • To avoid damage to your RAM, make sure RAM is removed and out of the way before beginning this step.
结论
Marianne
于09/08/14注册
647 声望
创作了6篇指南
团队
Pasco Hernando, Team 5-2, Prince Fall 2014 Pasco Hernando, Team 5-2, Prince Fall 2014 的会员
PHSC-PRINCE-F14S5G2
10 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 343
