跳转到主内容
Toshiba Satellite A215-S4757 Display Screen Replacement
你所需要的
  1. Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: 步骤 1 中的图像 1,2 Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: 步骤 1 中的图像 2,2
    • First, remove the four rubber screw coverings located at the top corners and bottom corners of the screen.
    • Remove the four screws underneath each cover and place them somewhere secure.
  2. Toshiba Satellite A215-S4757 Display Screen Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite A215-S4757 Display Screen Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite A215-S4757 Display Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the plastic paneling around the screen, and at the bottom of the display.
    • You may need a plastic opening tool to pry the back crease open.
  3. Toshiba Satellite A215-S4757 Display Screen Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite A215-S4757 Display Screen Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite A215-S4757 Display Screen Replacement: 步骤 3 中的图像 3,3
    • Remove the three screws on each side of the display, and place them somewhere secure.
  4. Toshiba Satellite A215-S4757 Display Screen Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite A215-S4757 Display Screen Replacement: 步骤 4 中的图像 2,2
    • Gently move the display forward so you can see the back of the component.
  5. Toshiba Satellite A215-S4757 Display Screen Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite A215-S4757 Display Screen Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite A215-S4757 Display Screen Replacement: 步骤 5 中的图像 3,3
    • On the back of the display, there is a wire that is plugged in to the display and secured with tape.
    • Gently lift the tape, leaving it attached to the wire.
    • Pull the wire out of its socket in the display backing.
    • The display is now fully detached!
结论
另外一个人完成了本指南。
Jacob Brown
于10/10/16注册
409 声望
创作了3篇指南
团队
Texas Tech, Team 12-2, Bennett Fall 2016 Texas Tech, Team 12-2, Bennett Fall 2016 的会员
TTU-BENNETT-F16S12G2
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 367
