跳转到主内容
Toshiba Satellite A215-S4757 Battery Replacement
你所需要的
  1. Toshiba Satellite A215-S4757 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Before removing anything on your Toshiba Satellite, make sure your computer is turned off, and your power adapter is not plugged in.
  2. Toshiba Satellite A215-S4757 Battery Replacement: 步骤 2 中的图像 1,1
    • Turn your Satellite over and locate your battery.
    • Locate the battery clips.
    • With your thumb and pointer fingers slide them outward at the same time, and hold.
  3. Toshiba Satellite A215-S4757 Battery Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite A215-S4757 Battery Replacement: 步骤 3 中的图像 2,2
    • Gently lift the battery out of its socket until completely removed and release the clips.
    • Your battery is now removed from your computer.
结论
2等其他人完成本指南。
Jacob Brown
于10/10/16注册
409 声望
创作了3篇指南
团队
Texas Tech, Team 12-2, Bennett Fall 2016 Texas Tech, Team 12-2, Bennett Fall 2016 的会员
TTU-BENNETT-F16S12G2
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 293
