跳转到主内容
Toshiba Satellite A215 S4697 RAM Replacement
你所需要的
  1. Toshiba Satellite A215 S4697 RAM Replacement, RAM: 步骤 1 中的图像 1,3 Toshiba Satellite A215 S4697 RAM Replacement, RAM: 步骤 1 中的图像 2,3 Toshiba Satellite A215 S4697 RAM Replacement, RAM: 步骤 1 中的图像 3,3
    • Close the laptop and turn it over so that the base is facing upwards and the spine is away from you.
    • Unscrew the two captive screws with the Phillips #1 and open the compartment.
    • The captive screws cannot be removed from the lid.
  2. Toshiba Satellite A215 S4697 RAM Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite A215 S4697 RAM Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite A215 S4697 RAM Replacement: 步骤 2 中的图像 3,3
    • Pull the two tabs away from the RAM so that the RAM will be removable.
    • Make sure to gently pull the RAM away from the base connections in the device. Do not use excessive force or other tools to remove it.
  3. Toshiba Satellite A215 S4697 RAM Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite A215 S4697 RAM Replacement: 步骤 3 中的图像 2,2
    • After the old RAM has been removed, insert the new RAM stick and ensure that they are oriented in the correct direction before installation. This can be done by lining up the gold connections to each other.
结论
6等其他人完成本指南。
团队
Cal Poly, Team 4-12, Maness Spring 2013 Cal Poly, Team 4-12, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G12
4 名成员
创作了18篇指南
一条评论
ned solution for my satitillate pro as the fix i need is not listed . my Toshiba is a l875d-s7332 and cu
ls not find the right as the fix given is for and older moldel, can i pls get the right data mailed to my email asasp pls
wendell burgess - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 15
总计 2,846
