你所需要的
Place laptop right side up on a flat and clean surface. Open the laptop.
Find the strip just above the keyboard and locate the gaps behind the F1, F8, and Insert keys.
Remove the strip by sticking your plastic opening tool into these gaps in order, and pulling up.
Find the ribbon cable that connects the keyboard to the laptop. Look for the black tabs on both sides of cable at the laptop end of the cable.
Using a pair of tweezers, pull the black tabs on both sides of the cable connector towards the screen until the cable can be pulled out easily.
Pull out the cable and completely remove the keyboard.
Begin by carefully removing the rubber bumper pads located at each corner of the plastic screen casing.
Using a Phillips screwdriver you may unscrew and remove the screws located directly under the the rubber bumper pads. Remember to keep track of the removed screws!
Refer to Toshiba Satellite screen replacement guide to remove screens outer shell.
Next remove the latch with a set of tweezers by gently squeezing the back of the latch to free it from the outer casing.
Locate the spring on the inside edge of the casing. It is located on the top left side of the screen casing and is connected to the latch arm.
Remove the spring by carefully pulling it off of the latch arm. Be careful not to lose the spring!
Now you can remove the latch arm by sliding it to the left and popping in out of place.
