跳转到主内容
Toshiba Satellite A215 S4697 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite A215 S4697 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite A215 S4697 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite A215 S4697 Hard Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
    • Find the battery compartment.
    • Slide the left slider which is just beneath the battery compartment into its leftmost position.
  2. Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
    • Do not touch the gold nodes inside the compartment.
  3. Toshiba Satellite A215 S4697 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,2 Toshiba Satellite A215 S4697 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Locate the hard drive in the left hand corner, and remove the two 4mm Phillips #1 screws.
  4. Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Using a plastic opening tool, open the compartment and remove the compartment cover.
  5. Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Use a pair of metal tweezers to grab the plastic pull-tab that is tucked in underneath the hard drive.
  6. Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 6 中的图像 1,3 Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 6 中的图像 2,3 Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Using the plastic pull-tab, carefully pull the hard drive to the left to detach it from its connector.
    • Remove the hard drive assembly from the device.
    • This assembly consists of the actual hard drive and the metal housing. Metal housing is necessary for the reassembly of the device.
  7. Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Flip over the hard drive assembly and remove two 4mm Phillips #1 screws at the top left and right side of the hard drive housing.
  8. Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite A215 S4697 Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Carefully separate the actual hard drive from the hard drive assembly.
    • Do not touch the hard drive's connectors.
结论
14等其他人完成本指南。
团队
Cal Poly, Team 4-12, Maness Spring 2013 Cal Poly, Team 4-12, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G12
4 名成员
创作了18篇指南
2条评论
What if I don't have the metal housing
Joshua Helms - 回复
I bought the laptop from someone and it didn't have the metal housing and the laptop just keeps going from startup screen to loading back and fourth can someone help
Joshua Helms - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 32
总计 32,918
