跳转到主内容
Toshiba Satellite A215 S4697 Battery Replacement
  1. Toshiba Satellite A215 S4697 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite A215 S4697 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite A215 S4697 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
    • Find the battery compartment.
    • Slide the left slider which is just beneath the battery compartment into its leftmost position.
  2. Toshiba Satellite A215 S4697 Battery Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite A215 S4697 Battery Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite A215 S4697 Battery Replacement: 步骤 2 中的图像 3,3
    • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
    • Do not touch the gold nodes inside the compartment.
结论
2等其他人完成本指南。
Grace Cowell
于04/15/13注册
273 声望
创作了2篇指南
团队
Cal Poly, Team 4-12, Maness Spring 2013 Cal Poly, Team 4-12, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G12
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 1,076
