跳转到主内容
Toshiba Satellite A210 Optical Disc Drive Replacement
你所需要的
  1. Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Optical Disc Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite A210 Optical Disc Drive Replacement: 步骤 2 中的图像 2,2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: 步骤 3 中的图像 1,2 Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: 步骤 3 中的图像 2,2
    • Remove the screw holding the RAM cover with a PH1 screwdriver.
    • Remove the RAM cover.
  4. Toshiba Satellite A210 Optical Disc Drive Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite A210 Optical Disc Drive Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite A210 Optical Disc Drive Replacement: 步骤 4 中的图像 3,3
    • Push outwards on the metal tabs to release the RAM.
    • Remove the RAM. Some force may be needed.
    • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
  5. Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: 步骤 5 中的图像 1,3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: 步骤 5 中的图像 2,3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: 步骤 5 中的图像 3,3
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
结论
另外一个人完成了本指南。
Bret Wilson
于04/11/13注册
274 声望
撰写一个指南
团队
Cal Poly, Team 17-5, Regan Spring 2013 Cal Poly, Team 17-5, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G5
4 名成员
创作了18篇指南
一条评论
Question : if i this will my screen start working ng again
jessica johnson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,602
