当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Unplug the AC adapter and all other auxiliary components from the laptop.
Slide the battery lock tab away from the center of the laptop to unlock the battery.
Slide the battery release tab away from the center of the laptop and hold it.
Lifting from the small notch between the two tabs, pull the battery out of the laptop.
Unscrew the 4 highlighted screws with a PH1 screwdriver.
Orient the laptop so that the screen is open and facing you.
Slide the plastic opening tool underneath the top edge of the black plastic insert.
Pull it off and set aside.
Remove the 2 PH1 screws.
Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
取消:我没有完成这个指南。
2等其他人完成本指南。
与11其他贡献者
于04/11/13注册
40 声望
创作了2篇指南
徽章: 7
+ 4更多徽章
CPSU-REGAN-S13S17G5
4 名成员
创作了18篇指南
very useful. THANKS
ANDREAS - 2016年6月17日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 16
总计 2,599
