跳转到主内容
Toshiba Satellite A210 Keyboard Replacement
你所需要的
  1. Toshiba Satellite A210 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite A210 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Keyboard Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite A210 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  4. Toshiba Satellite A210 Keyboard Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite A210 Keyboard Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite A210 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  5. Toshiba Satellite A210 Keyboard Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite A210 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  6. Toshiba Satellite A210 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
结论
2等其他人完成本指南。
Youlen
于04/11/13注册
40 声望
创作了2篇指南
团队
Cal Poly, Team 17-5, Regan Spring 2013 Cal Poly, Team 17-5, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G5
4 名成员
创作了18篇指南
一条评论
very useful. THANKS
ANDREAS - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 2,585
