当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Slide the battery release tab away from the center of the laptop and hold it.
Lifting from the small notch between the two tabs, pull the battery out of the laptop.
Use a PH0 screwdriver to remove the screw holding the optical drive in place.
Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
The optical drive will then slide out.
Orient the laptop so that the screen is open and facing you.
Slide the plastic opening tool underneath the top edge of the black plastic insert.
Pull it off and set aside.
Close the laptop and flip it over.
Unscrew the 11 yellow circled screws with a PH1 screwdriver. These screws are larger in size.
Unscrew the 2 red and yellow circled screws with a PH1 screwdriver. These screws are shorter and thicker than the previous.
Unscrew the 1 green and yellow circled screw with a PH1 screwdriver. This screw is longer and thinner than the previous.
Flip the laptop over and open it so that the screen is facing you.
Locate the hinges on either side of the screen, which secure the display to the body of the laptop.
Unscrew the 2 screws in each hinge with a PH1 screwdriver.
The display is no longer connected to the laptop and could fall. Be careful not to drop it during the next steps.
Unfasten the connectors from the highlighted locations.
Disconnect by gently pulling on the fasteners which connect the wires to the laptop.
Pulling directly on the wires could cause permanent damage to the connectors or the wires themselves.
Unscrew the screw indicated by the yellow circle.
Unfasten the two connections shown.
Unscrew the two screws securing the fan to the laptop. Use a PH1 for the screw that is adjacent to the speaker and a PH0 for the other screw.
Lift up the fan and pull the black plastic tab away from the fan housing. Remove the fan.
Do not remove the metal fan housing. It is taped to a metal heat-sink and should not be removed.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
