跳转到主内容
Toshiba Satellite A210 Fan Replacement
你所需要的
  1. Toshiba Satellite A210 Fan Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite A210 Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Fan Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite A210 Fan Replacement: 步骤 2 中的图像 2,2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Fan Replacement, Optical Disc Drive: 步骤 3 中的图像 1,3 Toshiba Satellite A210 Fan Replacement, Optical Disc Drive: 步骤 3 中的图像 2,3 Toshiba Satellite A210 Fan Replacement, Optical Disc Drive: 步骤 3 中的图像 3,3
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
  4. Toshiba Satellite A210 Fan Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  5. Toshiba Satellite A210 Fan Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite A210 Fan Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite A210 Fan Replacement: 步骤 5 中的图像 3,3
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  6. Toshiba Satellite A210 Fan Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite A210 Fan Replacement: 步骤 6 中的图像 2,2
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  7. Toshiba Satellite A210 Fan Replacement: 步骤 7 中的图像 1,1
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
  8. Toshiba Satellite A210 Fan Replacement, Fan: 步骤 8 中的图像 1,1
    • Close the laptop and flip it over.
    • Unscrew the 11 yellow circled screws with a PH1 screwdriver. These screws are larger in size.
    • Unscrew the 2 red and yellow circled screws with a PH1 screwdriver. These screws are shorter and thicker than the previous.
    • Unscrew the 1 green and yellow circled screw with a PH1 screwdriver. This screw is longer and thinner than the previous.
  9. Toshiba Satellite A210 Fan Replacement: 步骤 9 中的图像 1,3 Toshiba Satellite A210 Fan Replacement: 步骤 9 中的图像 2,3 Toshiba Satellite A210 Fan Replacement: 步骤 9 中的图像 3,3
    • Flip the laptop over and open it so that the screen is facing you.
    • Locate the hinges on either side of the screen, which secure the display to the body of the laptop.
    • Unscrew the 2 screws in each hinge with a PH1 screwdriver.
    • The display is no longer connected to the laptop and could fall. Be careful not to drop it during the next steps.
  10. Toshiba Satellite A210 Fan Replacement: 步骤 10 中的图像 1,3 Toshiba Satellite A210 Fan Replacement: 步骤 10 中的图像 2,3 Toshiba Satellite A210 Fan Replacement: 步骤 10 中的图像 3,3
    • Unfasten the connectors from the highlighted locations.
    • Disconnect by gently pulling on the fasteners which connect the wires to the laptop.
    • Pulling directly on the wires could cause permanent damage to the connectors or the wires themselves.
    • Unscrew the screw indicated by the yellow circle.
  11. Toshiba Satellite A210 Fan Replacement: 步骤 11 中的图像 1,2 Toshiba Satellite A210 Fan Replacement: 步骤 11 中的图像 2,2
    • Slide the plastic opening tool underneath the edges of the upper casing, which is shown in the images.
  12. Toshiba Satellite A210 Fan Replacement: 步骤 12 中的图像 1,1
    • The LCD screen can now be removed from the laptop.
    • Lift the upper plastic casing and remove it from the lower half of the laptop.
  13. Toshiba Satellite A210 Fan Replacement: 步骤 13 中的图像 1,3 Toshiba Satellite A210 Fan Replacement: 步骤 13 中的图像 2,3 Toshiba Satellite A210 Fan Replacement: 步骤 13 中的图像 3,3
    • Unfasten the two connections shown.
    • Unscrew the two screws securing the fan to the laptop. Use a PH1 for the screw that is adjacent to the speaker and a PH0 for the other screw.
    • Lift up the fan and pull the black plastic tab away from the fan housing. Remove the fan.
    • Do not remove the metal fan housing. It is taped to a metal heat-sink and should not be removed.
结论
3等其他人完成本指南。
Youlen
于04/11/13注册
40 声望
创作了2篇指南
团队
Cal Poly, Team 17-5, Regan Spring 2013 Cal Poly, Team 17-5, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G5
4 名成员
创作了18篇指南
2条评论
THANKS , very useful,clear, lifesaver guide !!!
ANDREAS - 回复
Very good. I am impressed. Only one screw over at the end, for me that’s good! And the fan is sooo much quieter :)
les.moore - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 3,916
