跳转到主内容
Toshiba Satellite A205-S5812 WiFi Card Replacement
你所需要的
  1. Toshiba Satellite A205-S5812 WiFi Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off your laptop before beginning.
    • Turn the laptop over so the base of the laptop faces the ceiling.
  2. Toshiba Satellite A205-S5812 WiFi Card Replacement: 步骤 2 中的图像 1,1
    • Push the two plastic tabs retaining the battery into the chassis to each respective side. This will push the battery up slightly and release it from the bottom of the notebook.
  3. Toshiba Satellite A205-S5812 WiFi Card Replacement: 步骤 3 中的图像 1,1
    • Using a finger or small prying device, pull the battery upwards from the recessed area. Then, simply pull the battery out of the notebook and gently set it aside.
  4. Toshiba Satellite A205-S5812 WiFi Card Replacement, WiFi Card: 步骤 4 中的图像 1,1
    • Remove all the 3mm long screws on the underside of the laptop.
  5. Toshiba Satellite A205-S5812 WiFi Card Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite A205-S5812 WiFi Card Replacement: 步骤 5 中的图像 2,2
    • Remove the black plastic bezel above the keyboard by prying upwards with a flat object.
  6. Toshiba Satellite A205-S5812 WiFi Card Replacement: 步骤 6 中的图像 1,1
    • Remove the two Phillips #00 2mm long screws located under the bezel that hold the keyboard to the chassis.
  7. Toshiba Satellite A205-S5812 WiFi Card Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite A205-S5812 WiFi Card Replacement: 步骤 7 中的图像 2,2
    • Lift the top of the keyboard and press the pins retaining the keyboard ribbon cable towards the screen with a rubber spudger to release the keyboard from the laptop. Set the keyboard aside.
  8. Toshiba Satellite A205-S5812 WiFi Card Replacement: 步骤 8 中的图像 1,3 Toshiba Satellite A205-S5812 WiFi Card Replacement: 步骤 8 中的图像 2,3 Toshiba Satellite A205-S5812 WiFi Card Replacement: 步骤 8 中的图像 3,3
    • After removing the keyboard, gently pry upwards on the gold contacts holding the white and black WiFi antennae wires using a rubber spudger to release them from the card. Then, simply pull upwards and out to remove the card.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 974
