跳转到主内容
Toshiba Satellite A205-S5812 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite A205-S5812 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off your laptop before beginning.
    • Turn the laptop over so the base of the laptop faces the ceiling.
  2. Toshiba Satellite A205-S5812 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Push the two plastic tabs retaining the battery into the chassis to each respective side. This will push the battery up slightly and release it from the bottom of the notebook.
  3. Toshiba Satellite A205-S5812 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Using a finger or small prying device, pull the battery upwards from the recessed area. Then, simply pull the battery out of the notebook and gently set it aside.
  4. Toshiba Satellite A205-S5812 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Toshiba Satellite A205-S5812 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Remove the two 3mm Phillips #00 screws holding the hard drive bay cover in place.
  5. Toshiba Satellite A205-S5812 Hard Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite A205-S5812 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Remove the caddy by pulling it towards the left. This will disconnect the hard drive from the SATA interface.
    • Then, simply pull the caddy out of the notebook
  6. Toshiba Satellite A205-S5812 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • The hard drive will be held in the hard drive caddy by four 1.5mm Phillips PH00 screws. Remove these screws to remove the old drive and install a new hard drive or solid state drive.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 575
