跳转到主内容
Toshiba Satellite A205-S5812 DVD Drive Replacement
你所需要的
  1. Toshiba Satellite A205-S5812 DVD Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off your laptop before beginning.
    • Turn the laptop over so the base of the laptop faces the ceiling.
  2. Toshiba Satellite A205-S5812 DVD Drive Replacement: 步骤 2 中的图像 1,1
    • Push the two plastic tabs retaining the battery into the chassis to each respective side. This will push the battery up slightly and release it from the bottom of the notebook.
  3. Toshiba Satellite A205-S5812 DVD Drive Replacement: 步骤 3 中的图像 1,1
    • Using a finger or small prying device, pull the battery upwards from the recessed area. Then, simply pull the battery out of the notebook and gently set it aside.
  4. Toshiba Satellite A205-S5812 DVD Drive Replacement, DVD Drive: 步骤 4 中的图像 1,1
    • Remove the 3mm screw using a Phillips #00 screwdriver located beneath the RAM module cover. This screw holds the DVD drive in place.
  5. Toshiba Satellite A205-S5812 DVD Drive Replacement: 步骤 5 中的图像 1,1
    • Carefully slide the DVD drive out of the side of the laptop.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 317
